Which patches should I use for binutils, gcc and newlib?
    Till Straumann
    strauman at slac.stanford.edu
    Tue Jan 30 20:52:33 UTC 2007
Amalaye Oyake wrote:
> With some wheel spinning I was able to build everything and I am chugging
> happily along. I built the stuff by hand (which is usually my preferred
> way), because my host system is an 64bit x86 Ubuntu box ...
I love that - the counterpart of the famous 'I have a problem - please help'
posting: 'look - I have it working'...
T.
> As a Debian/Ubuntu person I used to be a bit biased against RPMs, but I have
> since discovered their usefulness (especially SRPMS).
> - AO
> -----Original Message-----
> From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
> [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
> Of Till Straumann
> Sent: Tuesday, January 30, 2007 12:23 PM
> To: Joel Sherrill
> Cc: rtems-users at rtems.org
> Subject: Re: Which patches should I use for binutils, gcc and newlib?
>>> Hello,
>>> I am trying to build Binutils Gcc (4.1.1) and Newlib on a 64bit Xeon
>>> host box running Ubuntu (64bit) ? my target system will be a i386 box.
>>> What are the correct patches for Binutils, Gcc and Newlib? I see a lot
>>> of /.diff/ files in http://www.rtems.com/ftp/pub/rtems/SOURCES/ that I
>>> don?t know if I am to use all of them or just the latest one ?
>> In general, it is always a single patch and choose the one with the
>> latest date. That
>> may NOT be the case for specific CPUs which may not work with the latest
>> version
>> of something or require a special patch.
> Just for the record...
>> For specific and absolutely correct information, check out
> I assume you mean to look in CVS. If I browse in cvsweb
> to [there is no 'rtems-XXX', just 'rtems']
> rtems/contrib/crossrpms/rtems4.7/<my_cpu>
> then I end up an the 'Attic' -- so much for 'absolutely correct information'
> It would help if the precise information about what toolkit and patch
> versions to use were available [or at least 'absolutely correct information'
> about where to find it]. Not everybody uses the pre-packaged RPMs.
> -- Till
>> rtems-XXX/contrib/crossrpms/rtemsX.Y/CPU/*.add
>> --joel
>>> Regards,
>>> * Amalaye Oyake *
>>> * Flight Software Applications & Data Product Mgmt */\
>>> * 818.393.7168 work 818.653.4748 cell *||
>>> * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
>>> @@@ personal opinions expressed represent only the views of the author
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>> *References*
