Which patches should I use for binutils, gcc and newlib?
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Tue Jan 30 22:01:16 UTC 2007
Till Straumann wrote:
> Amalaye Oyake wrote:
>> With some wheel spinning I was able to build everything and I am
>> chugging
>> happily along. I built the stuff by hand (which is usually my preferred
>> way), because my host system is an 64bit x86 Ubuntu box ...
> I love that - the counterpart of the famous 'I have a problem - please
> help'
> posting: 'look - I have it working'...
The script that cuts a tarball also grabs the RPM versions.  I have
hacked together
a script that reports what is in the SRPM associated with each RPM
installed at the
time it is run.
Does the attached output look vaguely useful or promising to anyone?
Ralf.. where are the SRPMs for:
rtems-4.7-yum-conf-0.4-1
rtems-4.7-apt-conf-0.4-1
-joel
--joel
> T.
>> As a Debian/Ubuntu person I used to be a bit biased against RPMs, but
>> I have
>> since discovered their usefulness (especially SRPMS).
>> - AO
>> -----Original Message-----
>> From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
>> [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On
>> Behalf
>> Of Till Straumann
>> Sent: Tuesday, January 30, 2007 12:23 PM
>> To: Joel Sherrill
>> Cc: rtems-users at rtems.org
>> Subject: Re: Which patches should I use for binutils, gcc and newlib?
>>>> Hello,
>>>> I am trying to build Binutils Gcc (4.1.1) and Newlib on a 64bit
>>>> Xeon host box running Ubuntu (64bit) ? my target system will be a
>>>> i386 box. What are the correct patches for Binutils, Gcc and
>>>> Newlib? I see a lot of /.diff/ files in
>>>> http://www.rtems.com/ftp/pub/rtems/SOURCES/ that I don?t know if I
>>>> am to use all of them or just the latest one ?
>>> In general, it is always a single patch and choose the one with the
>>> latest date. That
>>> may NOT be the case for specific CPUs which may not work with the
>>> latest version
>>> of something or require a special patch.
>> Just for the record...
>>> For specific and absolutely correct information, check out
>> I assume you mean to look in CVS. If I browse in cvsweb
>> to [there is no 'rtems-XXX', just 'rtems']
>> rtems/contrib/crossrpms/rtems4.7/<my_cpu>
>> then I end up an the 'Attic' -- so much for 'absolutely correct
>> information'
>> It would help if the precise information about what toolkit and patch
>> versions to use were available [or at least 'absolutely correct
>> information'
>> about where to find it]. Not everybody uses the pre-packaged RPMs.
>> -- Till
>>> rtems-XXX/contrib/crossrpms/rtemsX.Y/CPU/*.add
>>> --joel
>>>> Regards,
>>>> * Amalaye Oyake *
>>>> * Flight Software Applications & Data Product Mgmt */\
>>>> * 818.393.7168 work 818.653.4748 cell *||
>>>> * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
>>>> @@@ personal opinions expressed represent only the views of the author
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> *References*
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20070130/f86fd860/attachment.txt>
