New M68K target for GCC
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Tue Jan 16 15:37:53 UTC 2007
Kevin,
I would assume that the MCF5329 has the same CORE as the MCF5307, which
should be supported by GCC. Try option "-m5307"
wkr,
Thomas Doerfler
Kirspel, Kevin {Engineering - Osmetech CCD} schrieb:
> I want to patch GCC 4.1.1 to add the MCF532x CoreV3 Coldfire processors.
> I have the MCF5329EVB evaluation board and I want to get it running with
> RTEMS. I have checkout the rtems-4.7-branch from CVS and have patched
> it with a MCF5329EVB BSP. To my dismay, GCC does not recognize the
> -m5329 target option. I have never tried to update GCC to support a new
> target processor, but since similar m68k coldfire processors are
> supported I didn't think it would take to much work to get it to
> recognize the -m5329 option. Does anyone know the steps necessary to
> patch GCC to recognize the MCF5329 processor?
> Kevin Kirspel
> Research Engineer
> Osmetech
> kevin.kirspel at osmetech.com
> (ph) 770-510-4444 x4568
> (fax) 770-510-4445
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
