Event Problem in RTEMS 4.6.2
Eric Norum
norume at aps.anl.gov
Thu Jan 25 14:17:37 UTC 2007
The RTEMS event mechanism does not count the number of times an event
has been sent. For example, consider the following sequence of events:
1) Task A sends an event.
2) Task A sends the same event again.
3) Task B calls rtems_event_receive() and does not block since the
event is pending.
4) Task B calls rtems_event_receive() and does block, because the
event is no longer pending.
Perhaps you need to use a counting semaphore or a message queue to do
what you want.
On Jan 25, 2007, at 4:34 AM, Wilfried Busalski wrote:
> Hallo
> I'am using RTEMS 4.6.2 and I loose events send by rtems_event_send
> () and
> receivinf by rtems_event_receive().
> If I send more then 5 Event's at a short time, the first event is
> lossed.
> Any Ideas?
> Regards
> Wilfried
> rtems-users mailing list
> rtems-users at rtems.com
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
