rtems networking
nir levy nir.levy at bon-networks.com
Tue Jul 3 13:08:36 UTC 2007
I am using a batch file with the commands:
set QEMU=d:\qemu
start cmd.exe /k  %QEMU%\qemu -L %QEMU% -m 256 -boot a -fda
d:\rtems\i386\rtems-boot.img -hda fat:samples
sould I configure it differently for the loopback test? Since -net nic -net
user is default for qemu
Best,
Nir Levy
-----Original Message-----
From: Keith Robertson [mailto:kjrobert at alumni.uwaterloo.ca]
Sent: Tuesday, July 03, 2007 3:59 PM
To: nir levy
Cc: rtems-users at rtems.org
Subject: Re: rtems networking
nir levy wrote:
> Hi All,
> I am Very new to RTEMS but I am trying for some time now to run RTEMS
> under the QEMU emulator.
> I tried to compile it myself or take the pre prepared binaries for the
> RTEMS and QEMU (for i386) under windows (XPsp2) and under linux (fedora 6)
> But for some reason I cannot run the loopback tests or the netdemo test.
> I tried compiled tests and tried to compile them myself but no luck.
Do you have networking for qemu enabled and setup correctly?  What's
your setup and qemu configuration?
Keith
