rtems networking
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Jul 3 13:56:09 UTC 2007
nir levy wrote:
> I am using a batch file with the commands:
> set QEMU=d:\qemu
> start cmd.exe /k %QEMU%\qemu -L %QEMU% -m 256 -boot a -fda
> d:\rtems\i386\rtems-boot.img -hda fat:samples
> sould I configure it differently for the loopback test? Since -net nic -net
> user is default for qemu
You have to modify the network configuration to match the
NIC in used by the system. The loopback test is NOT BSP
specific and does NOT include a driver for any real NIC HW.
It only includes the generic loopback interface.
Use the network demos and use the attached networkconfig.h
as an example. I haven't tested networking on qemu recently
but this should be the last one I used.
You also have to set up a tunnel interface on the host system.
The qemu documentation has information on this.
--joel
> Best,
> Nir Levy
> -----Original Message-----
> From: Keith Robertson [mailto:kjrobert at alumni.uwaterloo.ca]
> Sent: Tuesday, July 03, 2007 3:59 PM
> To: nir levy
> Cc: rtems-users at rtems.org
> Subject: Re: rtems networking
> nir levy wrote:
>> Hi All,
>> I am Very new to RTEMS but I am trying for some time now to run RTEMS
>> under the QEMU emulator.
>> I tried to compile it myself or take the pre prepared binaries for the
>> RTEMS and QEMU (for i386) under windows (XPsp2) and under linux (fedora 6)
>> But for some reason I cannot run the loopback tests or the netdemo test.
>> I tried compiled tests and tried to compile them myself but no luck.
> Do you have networking for qemu enabled and setup correctly? What's
> your setup and qemu configuration?
> Keith
> rtems-users mailing list
> rtems-users at rtems.com
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070703/40906e41/attachment.bin>
