Request Help with NFS Client Test
Fri Jul 13 18:56:50 UTC 2007
Hi,
I have been trying to write a test for
the NFS client.  It fails with a weird
protection exception on the PowerPC
target I am using.
I have no idea whether I am configuring
RTEMS right for NFS or initializing the
NFS client correctly.
The filesystem exported has no restrictions
on it and is mountable from other computers.
Admittedly all of them are Fedora 7 so
it should work.
Attached is the test and log.  It assumes you
are building in the network-demos so you have
to have a networkconfig.h.  Also you will have
to change the mount command since I used an IP
address for the NFS server.
If someone can help get this working, I would
appreciate it.  I want to add this to the
network-demos.
--joel
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20070713/6bf1d0c7/attachment.txt>
Type: application/x-bzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070713/6bf1d0c7/attachment.bin>
