watchdog insertion order
shizheng
neversetsun at ustc.edu
Sat Jul 14 01:44:21 UTC 2007
Joel Sherrill wrote:
> shizheng wrote:
>> Hi,all:
>> As a result, the element in the watchdog chain has an opposite order to
>> the insertion order.
>> Did I miss something?
> No that's what happens. Timers that expire during the same clock
> tick will be executed in LIFO order. When the clock tick is over,
> all tasks unblocked will then compete for the CPU based upon their
> priority. This is done to avoid extending the search for timers
> at the same tick.
> Two of the proposed changes to RTEMS are
> + change this so it is FIFO for equal ticks
> + change the watchdog chains and timer scheduling so it is
> all in terms of seconds and nanoseconds since boot (absolute
> time) or wall time. This would get away from ticks entirely
> for these chains. This issue would not be a factor on BSPs with
> the nanosecond time support.
As for the second change, what's the problems with BSPs without
nanosecond time support?
I can just imagine the precision problem.
> --joel
>> regards, shizheng
