GameBoy Advance BSP
Markku Puro markku.puro at kopteri.net
Thu Jul 26 19:33:33 UTC 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all,
Joel Sherrill wrote:
> dave madden wrote:
>>>>>>> "JS" == Joel Sherrill <joel.sherrill at oarcorp.com> writes:
>>     JS> Is there anyone on the list who has used this?
>>     JS> I would like to get setup here to run it and would appreciate
>>     JS> some hints.
>> Hi Joel.  I've compiled the BSP and run the test apps under the
>> VisualBoy emulator (and, IIRC, I loaded a couple onto a flash cart and
>> ran them on a real GBA) but I haven't done any RTEMS development.  So,
>> if you're still at a pre-compile/test-environment stage and need help
>> getting further along, maybe I can be of some use.  Otherwise, you'll
>> have to wait for somebody else to pipe up.
> I'm not looking to change the BSP, just make sure it works.
> So it sounds like you can walk me through the process of
> setting up the simulator and running it.
> Once I get that working, I need to check if my kids haven't broken
> or sold their GBA's now that most of them had DS's.  If they have
> one still, I will probably buy a cartridge programming system
> and try that.  It is just too neat to pass up.
> So where do I get the simulator?  If there are multiple ones, do
> you know how to run it on them?
Joel, didn't You check RTEMS wiki ;)
<http://www.rtems.com/wiki/index.php/ToolsForGameBoyAdvance>
There is some links for emulators, simulators and debuggers etc.
I just reform some links of gba page, I hope its better now.
<http://www.rtems.com/wiki/index.php/Gba>
If somebody knows nice tools, quides, flashlinkers etc
please update to those gba wiki-pages.
- -Mp
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (MingW32)
iQEVAwUBRqj3Dda56rpac4uCAQJg1ggAozcDyWVRkJApT9/HcBm2SIyDsQ0i8//4
ZRcmz+Bl1Gd6e7XXo/bngy3YwwoDrXQG9D3TnWisY8m/JyGliR1iRjBQzjbHBYBe
wTBkv165DRj+IwA/3D5rwlsg0CEeES4tH7wOtAm9Uol9yIlqTWXqWRccLmDyceor
JEFfTNcU/Nh/qhdNb+vjoksqifQ/4gRKWQ+u07CIL61Iw6qlE8Zv9zSfjzuEmRVu
fwYBn09C6xlFMIfWCs8LGf+LFk2hC2lrsShhs1exsyzv/o191rSypK8xyzvnzkjP
384VvbsR9x34PmJaRKaYDpejHmrhueWet1z65AwlGxojjVF00XGT2A==
=784f
-----END PGP SIGNATURE-----
