Gdb configuration and compilation
Till Straumann strauman at slac.stanford.edu
Thu Jul 26 20:31:13 UTC 2007
Thomas Doerfler (nt) wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> the gdb configuration you are referring to is outdated. RPC based
> debugging has been implemented years ago and unfortunately has not been
> maintained.
> Try the gdb agent implementation from Till Straumann instead, you may
> want to search the rtems mailing list archive for references.
You can find it here:
http://www.slac.stanford.edu/~strauman/rtems/gdb/
this thread just inspired me to cut a new (1.4) release
in order to get a few bugfixes out.
T.
> wkr,
> Thomas.
> Dr Chris Lee schrieb:
>> Hi
>> I am trying to remotely debug via ethernet. I am using rtems 4.7.1 on a
>> i386 target. The gdb version is 6.5 with the rtems-20060713.diff patch
>> applied
>> >From what I have seen in the mailing list I should configure the gdb
>> build with --target=i386-RTEMS which I do, but when I then perform "make
>> all" it fails when checking the target system type because it does not
>> recognise RTEMS and claims it is an invalid system configuration.
>> Could some one give me a hint what I may be doing wrong.
>> With best regards
>> Chris Lee
>> wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
>>                     <000><
>>      ><00>                                        <OOO><
>>                                  ><00>
>> Christopher Lee					Tel:  +49-6202-5756-25
>> von Hoerner & Sulger GmbH			Fax:  +49-6202-5756-55
>> Schlossplatz 8
>> Schwetzingen					Email: lee at vh-s.de
>> D-68723						Web:   www.vh-s.de
>> Germany
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>      http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFGqOGywHyg4bDtfjQRApkVAJ4uax4qKt7ktowOwFRAd0jmKqQvEgCgkHwV
> ihVHfH1ZnQ8VEyVLNuVwGG0=
> =XPAc
> -----END PGP SIGNATURE-----
