task delete and semaphore
Paul Whitfield
paulw at omnitronics.com.au
Mon Jul 2 07:59:47 UTC 2007
WuHao wrote:
> How does the task to be deleted get all resources it holds?
> Typically when the task holds tty's write mutex.
> Paul Whitfield wrote:
As described in the manual, you should signal the task to clean up
and delete itself.
As per the manual:
If a task holds RTEMS resources, the task should be allowed to
deallocate its resources before deletion. A task can be directed to
release its resources and delete itself by restarting it with a special
argument or by sending it a message, an event, or a signal.
Regards
Paul .
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
