task delete and semaphore
Paul Whitfield
paulw at omnitronics.com.au
Tue Jul 3 00:21:19 UTC 2007
Please keep this discussion on the RTEMS mailing list,
as that way people who know about the internals of
termios can respond
>>> How does the task to be deleted get all resources it holds?
>>> Typically when the task holds tty's write mutex.
>> As described in the manual, you should signal the task to clean up
> Suppose the task to be deleted gets CPU and begins to do clean up.
> But it is holding a tty write mutex(osem), how can it release the mutex
> since
> termios does not provide any directive to do so?
I hope I am not missing something here!
The point is you should not delete a task by calling rtems_task_delete
from ANOTHER task.
You should send a message, event or signal to the task which then
cleans up and deletes itself. This includes releasing any held
semaphore and closing any open termios ports.
This message will only be received by the task to be
deleted when it has *finished* its termios processing,
and therefore at that point it will not be holding
semaphores or other resources.
Looking at rtems_termios_write, it will release
the semaphore tty->osem
I hope that makes sense.
Regards
Paul
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
