Webserver Woes with mcf5235 (BCC) and rtems 4.7.1
Paul Whitfield
paulw at omnitronics.com.au
Mon Jul 9 00:30:42 UTC 2007
CWolfe at motioncontrol.org wrote:
> Hi All,
> I recently fixed the network driver for the bsp, and would like to use the GoAhead
> webserver, but I have been having issues with serving pages. For some unknown reason,
> illegal characters are being injected into/showing up in the http responses. While I feel
> confident that It is a driver/configuration issue, I am not sure where to start. I have attempted
> changing buffer descriptor alignment, MTU size, mbuf and mbuf cluster sizes, Usecs per tick
> and some other random odds and ends. At one poijnt yesterday, for a few hours, the problem
> vanished mysteriously, and the webserver was running correctly, though such is not the case
> now. I have checked the contents of the files in flash, and they are correct, so the erors are
> definitely being produced by the network driver/stack, but i don't know why. From ethereal, I
> have noticed that the checksums are bad in all of the packets sent out from the board, but I
> don't know how much that helps or not. I would appreciate any advice anyone could give.
> Best Regards,
> Christopher Wolfe
One thing that caught me on a different variant of the coldfire(5270)
is that the buffer descriptors must be aligned to certain boundaries.
The from memory the symptoms were similar.
Looking in the 5235 manual it says:
"Buffer descriptor rings *must* start on a 32-bit boundary; however, it
is recommended they are made 128-bit aligned."
You could try making the bd be alligned on a 128 bit boundary?
The other thing that "bit" me was interactions between the
cache and the FEC, to fix it I invalidated the cache in the FEC ISR.
All of this is on a different processor variant, so YMMV.
Hope that helps
Regards
Paul Whitfield.
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
