UART console based on interrupt
Grigori Khmyrov
Grigori_Khmyrov at uml.edu
Thu Jul 19 13:42:56 UTC 2007
John,
Can you please share or point to how do you measure CPU usage.
Thank you,
Grigori
John Pickwick wrote:
> Hi to all,
> I recently re-compiled my SparcLEON2 BSP / RTEMS4.7.1 using the
> USE_CONSOLE_INTERRUPT macro and I compared the CPU usage with the
> default BSP version that uses polled UART.
> I have a task waiting on console input with getchar and I expected the
> interrupt driven version of the console to be less CPU consuming.
> Unfortunately I find the same CPU usage percentage for that one.
> Can someone explain this ?
> Best regards,
> John
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20070719/a2e65ff2/attachment-0001.html>
