UART console based on interrupt
John Pickwick
john.pickwick at free.fr
Fri Jul 20 16:26:51 UTC 2007
Through the classical CPU_DumpUsage function call. Sometimes you need to reset the statitistics otherwise the wrapped counter gives wrong figures.
In my case of interrupt driven io I expected to get a lower CPU usage by the console task since I assumed it wakes up only "when there is something to process". This is not the case, the figure is the same as with the polled version. :=(
John.
----- Original Message -----
To: rtems-users at rtems.org
Sent: Thursday, July 19, 2007 3:42 PM
Subject: Re: UART console based on interrupt
John,
Can you please share or point to how do you measure CPU usage.
Thank you,
Grigori
John Pickwick wrote:
Hi to all,
I recently re-compiled my SparcLEON2 BSP / RTEMS4.7.1 using the USE_CONSOLE_INTERRUPT macro and I compared the CPU usage with the default BSP version that uses polled UART.
I have a task waiting on console input with getchar and I expected the interrupt driven version of the console to be less CPU consuming. Unfortunately I find the same CPU usage percentage for that one.
Can someone explain this ?
Best regards,
John
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20070720/0e632961/attachment-0001.html>
