Unable to create TX buffer recovery queue
Amalaye Oyake amalaye.oyake at jpl.nasa.gov
Tue Jun 5 23:21:53 UTC 2007
Hello,
I am using RTEMS on a i386 system (a 400Mhz Pentium II with 128MB of RAM).
The NIC is a 3C905B (3COM Card) ... RTEMS finds the NIC, does a timer setup,
identifies the media and says unit elnk1 driver attached.
Then it says
RTEMS: etherlink : Unable to create TX Buffer recovery queue
RTEMS: fatal error, exiting
What do the above errors mean? How can I fix this?
* Amalaye Oyake                                    *
* Flight Software Applications & Data Product Mgmt */\
* 818.393.7168 work   626.399.1707 cell            *||
* Jet Propulsion Laboratory, Pasadena  CA 91109   */||\
