Unable to create TX buffer recovery queue
Amalaye Oyake
amalaye.oyake at jpl.nasa.gov
Wed Jun 6 00:31:03 UTC 2007
Setting MANAGERS=all may be one step but don't some of the
#define CONFIGURE_MAXIMUM_XYZs have default values of 0?
I may need to assign some values to these perhaps?
-AO
-----Original Message-----
From: Daron Chabot [mailto:djc915 at mail.usask.ca]
Sent: Tuesday, June 05, 2007 5:11 PM
To: Amalaye Oyake
Cc: RTEMS
Subject: Re: Unable to create TX buffer recovery queue
On 5-Jun-07, at 5:21 PM, Amalaye Oyake wrote:
> Hello,
> I am using RTEMS on a i386 system (a 400Mhz Pentium II with 128MB
> of RAM).
> The NIC is a 3C905B (3COM Card) ... RTEMS finds the NIC, does a
> timer setup,
> identifies the media and says unit elnk1 driver attached.
> Then it says
> RTEMS: etherlink : Unable to create TX Buffer recovery queue
> RTEMS: fatal error, exiting
> What do the above errors mean? How can I fix this?
Have a look at the driver source, elnk.c, line 3525:
if (txDaemonTid == 0)
if( rtems_message_queue_create( rtems_build_name
('X','L','c','r'),
sc->numTxbuffers+1,
sizeof(struct TXMD *),
RTEMS_FIFO | RTEMS_LOCAL,
&chainRecoveryQueue ) !=
RTEMS_SUCCESSFUL )
rtems_panic( "etherlink : Unable to create TX buffer
recovery queue\n" );
i.e. the directive, rtems_message_queue_create( ), is failing...
I'm going to guess that you haven't included the Message Manager in
your application's Makefile. If memory is not an issue (and 128 MB is
*lots* to play with...), just set the "Managers" variable to "all":
i.e. in your Makefile set
MANAGERS=all
That will circumvent several obscure "gotchyaz"...
-- dc
