C++ Usage Issues - Problems, Solutions, and Suggestions
Thu Jun 21 15:15:20 UTC 2007
Robert S. Grimes wrote:
> Joel Sherrill wrote:
>> So you don't have to page to the bottom..
>> + I think the CONFIGURE_TEST_XXX uses should be
>> fixed now.  Or at least confdefs.h will give an error that
>> they are obsolete.  I got bit by this one on some code myself.
> The example in Chapter 25 of the "RTEMS C Users Guide" also has this
> near the bottom:
> #define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER  /* for stdio */
> #define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER    /* for time services */
> Perhaps a global grep on CONFIGURE_TEST is a good idea?  :-)
That appears to be gone in CVS.
I have also fixed this in the network-demos along
with the confdefs.h -> rtems/confdefs.h.
Check out the network demos from CVS and see if
they are closer to being right for you now.
>> + Please send a patch for everything you changed.  I don't
>> care about the .c->.cc changes but the ones that improve
>> the correctness of the code are VERY important.
> Okay, will do
Thanks.
>> + I obviously need to add the network demos to the automated
>> build sweep.  When networking is configured, I should at least
>> compile all demos with the loopback driver configured.
> Good idea!
> Thanks, guys!
> -Bob
