GCC 4.1.1 m68k-rtems generating invalid code for -m5307 processor ?
Kirspel, Kevin
kevin.kirspel at optimedical.com
Fri Jun 22 18:23:27 UTC 2007
I have built the following environment for the m68k-rtems target:
binutils-2.17 with patch binutils-2.17-rtems4.7-20061021.diff
gcc-4.1.1 with patch gcc-core-4.1.1-rtems4.7-20070102.diff
newlib-1.14.0 with patch newlib-1.15.0-rtems4.7-20070208.diff
I have created an MCF5329EVB BSP in the RTEMS 4.7 branch. Since GCC 4.1.1
does not support the MCF5329 processor I had to use the -m5307 option to
generate V3 code ( I think this should work ). The RTEMS compilation was
successfully. Using GDB, I ran the hello.exe sample test. The hello.exe
fails during the _IO_Manager_initialization() function where is calls
memset(). After single stepping through memset(), the programmed dies when
the PC reaches the instruction at 0x400149ea. I disassembled hello and got
the following output for memset():
400149cc <memset>:
400149cc: 4e56 0000 linkw %fp,#0
400149d0: 2f03 movel %d3,%sp at -
400149d2: 2f02 movel %d2,%sp at -
400149d4: 262e 0008 movel %fp@(8),%d3
400149d8: 226e 0010 moveal %fp@(16),%a1
400149dc: 2203 movel %d3,%d1
400149de: 4282 clrl %d2
400149e0: 142e 000f moveb %fp@(15),%d2
400149e4: 7003 moveq #3,%d0
400149e6: b089 cmpl %a1,%d0
400149e8: 6406 bccs 400149f0 <memset+0x24>
400149ea: e8c3 0164303
400149ec: 0782 bclr %d3,%d2
400149ee: 6712 beqs 40014a02 <memset+0x36>
400149f0: 4a89 tstl %a1
400149f2: 6758 beqs 40014a4c <memset+0x80>
400149f4: 1002 moveb %d2,%d0
400149f6: 2041 moveal %d1,%a0
400149f8: d3c1 addal %d1,%a1
400149fa: 10c0 moveb %d0,%a0 at +
400149fc: b3c8 cmpal %a0,%a1
400149fe: 66fa bnes 400149fa <memset+0x2e>
40014a00: 604a bras 40014a4c <memset+0x80>
40014a02: 2043 moveal %d3,%a0
40014a04: 2002 movel %d2,%d0
The instruction at 0x400149ea is bogus. Are there any issues with
binutils/gcc and -m5307 option? Is there some configuration option in rtems
that would cause this?
URL: <http://lists.rtems.org/pipermail/users/attachments/20070622/65a41ff3/attachment.html>
