GCC 4.1.1 m68k-rtems generating invalid code for -m5307 processor ?
Eric Norum
norume at aps.anl.gov
Fri Jun 22 18:31:25 UTC 2007
Can you check the memory contents *before* starting the program?
On Jun 22, 2007, at 1:23 PM, Kirspel, Kevin wrote:
> I have built the following environment for the m68k-rtems target:
> binutils-2.17 with patch binutils-2.17-rtems4.7-20061021.diff
> gcc-4.1.1 with patch gcc-core-4.1.1-rtems4.7-20070102.diff
> newlib-1.14.0 with patch newlib-1.15.0-rtems4.7-20070208.diff
> I have created an MCF5329EVB BSP in the RTEMS 4.7 branch. Since
> GCC 4.1.1 does not support the MCF5329 processor I had to use the –
> m5307 option to generate V3 code ( I think this should work ). The
> RTEMS compilation was successfully. Using GDB, I ran the hello.exe
> sample test. The hello.exe fails during the
> _IO_Manager_initialization() function where is calls memset().
> After single stepping through memset(), the programmed dies when
> the PC reaches the instruction at 0x400149ea. I disassembled hello
> and got the following output for memset():
> 400149cc <memset>:
> 400149cc: 4e56 0000 linkw %fp,#0
> 400149d0: 2f03 movel %d3,%sp at -
> 400149d2: 2f02 movel %d2,%sp at -
> 400149d4: 262e 0008 movel %fp@(8),%d3
> 400149d8: 226e 0010 moveal %fp@(16),%a1
> 400149dc: 2203 movel %d3,%d1
> 400149de: 4282 clrl %d2
> 400149e0: 142e 000f moveb %fp@(15),%d2
> 400149e4: 7003 moveq #3,%d0
> 400149e6: b089 cmpl %a1,%d0
> 400149e8: 6406 bccs 400149f0 <memset+0x24>
> 400149ea: e8c3 0164303
> 400149ec: 0782 bclr %d3,%d2
> 400149ee: 6712 beqs 40014a02 <memset+0x36>
> 400149f0: 4a89 tstl %a1
> 400149f2: 6758 beqs 40014a4c <memset+0x80>
> 400149f4: 1002 moveb %d2,%d0
> 400149f6: 2041 moveal %d1,%a0
> 400149f8: d3c1 addal %d1,%a1
> 400149fa: 10c0 moveb %d0,%a0 at +
> 400149fc: b3c8 cmpal %a0,%a1
> 400149fe: 66fa bnes 400149fa <memset+0x2e>
> 40014a00: 604a bras 40014a4c <memset+0x80>
> 40014a02: 2043 moveal %d3,%a0
> 40014a04: 2002 movel %d2,%d0
> The instruction at 0x400149ea is bogus. Are there any issues with
> binutils/gcc and -m5307 option? Is there some configuration option
> in rtems that would cause this?
> rtems-users mailing list
> rtems-users at rtems.com
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
