ticker of csp337 works well
Ray
xr at trasin.net
Mon Jun 18 12:28:11 UTC 2007
GOOD WORKS !
Seems the at91rm9200 support is full functional in terms of samples. When will your codes get into skyeye's release?
Btw, is there anyone test the network support£¿
Thanks & Best Regards!
Ray
2007-06-18
Date: 2007-06-17 19:25:46
To: RTEMS Users; Skyeyee<, e h d8 g (i .d,6e h!(
CC: blackfin.kang at gmail.com
Sub: ticker of csp337 works well
>>After i implemented the full features of AIC,then ticker works well.
>*** CLOCK TICK TEST ***
>TA1 - rtems_clock_get - 09:00:00 12/31/1988
>TA2 - rtems_clock_get - 09:00:00 12/31/1988
>TA3 - rtems_clock_get - 09:00:00 12/31/1988
>TA1 - rtems_clock_get - 09:00:05 12/31/1988
>TA2 - rtems_clock_get - 09:00:10 12/31/1988
>TA1 - rtems_clock_get - 09:00:10 12/31/1988
>TA3 - rtems_clock_get - 09:00:15 12/31/1988
>TA1 - rtems_clock_get - 09:00:15 12/31/1988
>TA2 - rtems_clock_get - 09:00:20 12/31/1988
>TA1 - rtems_clock_get - 09:00:20 12/31/1988
>TA1 - rtems_clock_get - 09:00:25 12/31/1988
>TA3 - rtems_clock_get - 09:00:30 12/31/1988
>TA2 - rtems_clock_get - 09:00:30 12/31/1988
>TA1 - rtems_clock_get - 09:00:30 12/31/1988
>*** END OF CLOCK TICK TEST ***
>I will subbmit a patch for skyeye later.There is not any problem with
>bsp of 337.
>but just cause skyeye has not implemented the function of real
>hardware completely.
>In at91rm.h ,the macros has not been translated to unsigned number,and
>for example #define AIC_SVR AT91RM92_AIC_BASE0+128 .I think it is dangerous.
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
