MPC5200 Lite Board
Mon Jun 18 21:59:06 UTC 2007
Amalaye Oyake wrote:
> Did they write a driver for the Fast Ethernet Controller (FEC) on the board
> (or is there a driver already)?
I am using Thomas Doerfler's gen5200 BSP which does
support the FEC.
> Also some of the other Embedded Planet boards use the Micrel Ethernet
> Controller chip. Are there drivers for the Micrel chips?
According to U-Boot's message when it loads via tftp, it is
using the FEC.
I don't know about a driver for the Micrel chip but then again
I didn't remember the if_fxp driver this morning either. :)
--joel
> Regards,
> A. Oyake
> -----Original Message-----
> From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
> [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
> Of Joel Sherrill
> Sent: Monday, June 18, 2007 2:25 PM
> To: RTEMS Users; Duncan Winn; Nickolay Kolchin; Thomas Doerfler
> Subject: MPC5200 Lite Board
> Hi,
> I am playing with an Embedded Planets EP5200C which
> they have told me is the same as the MPC5200 LITE
> evaluation board from Freescale.  I belive this
> claim as I have built a U-Boot and Linux kernel
> for this board using MPC5200 LITE instructions.
> It looks like back in February, Thomas Doerfler
> was helping Duncan Winn and Nickolay Kolchin
> try to get RTEMS up on this board variant.
> The thread starts here:
> http://www.rtems.com/ml/rtems-users/2007/february/msg00095.html
> Can someone tell me if this effort succeeded?
> If so, which BSP variant did you use?  What mkimage command
> worked?
> The thread ends with a kind of working .. garbage on the
> console message.
> Thanks.
> -joel
> rtems-users mailing list
> rtems-users at rtems.com
