Network cable disconnect
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Jun 20 16:26:17 UTC 2007
Camilo Alejandro Arboleda wrote:
> Hello,
> We working with a PC386 based board, with NE2000 compatible network
> adapter. I've seen that disconnecting the network cable doesn't cause
> the "write()" function to fail immediately, but it takes about a
> minute to detect the network disconnection. Is it possible to detect
> cable faults faster? Am I doing something wrong?
Did you turn on debug in the driver and try it?
Is there any output at all from the driver now?
I don't see anything explicitly in the driver about cable disconnect.
I do see ne_watchdog which is hooked to if_watchdog. The
associated if_timer value is 2 which I think is 2 seconds based
upon IFNET_SLOWHZ and hz being rtems_bsdnet_ticks_per_second.
But this looks like a Tx timeout and is way shorter than what you
are seeing.
--joel
> Thanks,
> Camilo
> rtems-users mailing list
> rtems-users at rtems.com
