C++ Usage Issues - Problems, Solutions, and Suggestions
Thu Jun 21 15:43:34 UTC 2007
Robert S. Grimes wrote:
> Ralf Corsepius wrote:
>>>     LD_LIBS   += -lstdc++
>> No, using "<target>-gcc -lstdc++" is never correct. You have to use
>> "<target>-g++" instead of "<target>-gcc" to link c++ code.
> Oops, I missed that - of course, I didn't know that I had.  I was about
> to ask, but then a bit of poking around led me to virtex.cfg, where
> there is a make-cxx-exe rule, which indeed fixes it correctly - Thanks Ralf!
> For others who may be in my "naive" camp, the rule in the Template
> makefile (make/Templates/Makefile.leaf) that links a C executable looks
> like this:
>     ${ARCH}/xxx-your-program-here: ${OBJS} ${LINK_FILES}
>         $(make-exe)
> For C++ applications, change it to this:
>         $(make-cxx-exe)
> Joel, maybe this should also be in the Template file, at least a
> commented-out version?  I'm not sure I ever would have figured out the
> correct way to link if Ralf had not corrected me.
That's not a bad idea.  I just did it.
>>> The other errors are due to the rtems/rtems_bsdnet.h header file, and
>>> can be eliminated by changing the inclusion of this file like this:
>>>     extern "C" {
>>>     #include <rtems/rtems_bsdnet.h>
>> If this works, you've found a bug inside of this header. This header must be C-safe.
> Yes, this header is not correct.
I just committed a fix for this and the others in the libnetworking/rtems
directory that were not doing an extern "C".
--joel
>> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
