C++ Usage Issues - Problems, Solutions, and Suggestions
Robert S. Grimes
rsg at alum.mit.edu
Thu Jun 21 16:07:11 UTC 2007
Joel Sherrill wrote:
> Robert S. Grimes wrote:
>> Ralf Corsepius wrote:
>>> No, using "<target>-gcc -lstdc++" is never correct. You have to use
>>> "<target>-g++" instead of "<target>-gcc" to link c++ code.
>> Oops, I missed that - of course, I didn't know that I had. I was about
>> to ask, but then a bit of poking around led me to virtex.cfg, where
>> there is a make-cxx-exe rule, which indeed fixes it correctly -
>> Thanks Ralf!
>> For C++ applications, change it to this:
>> ${ARCH}/xxx-your-program-here: ${OBJS} ${LINK_FILES}
>> $(make-cxx-exe)
>> Joel, maybe this should also be in the Template file, at least a
>> commented-out version? I'm not sure I ever would have figured out the
>> correct way to link if Ralf had not corrected me.
> That's not a bad idea. I just did it.
Thanks - it should help keep us rookie C++ coders from hassling you
hardened C-jockeys! ;-)
> I just committed a fix for this and the others in the libnetworking/rtems
> directory that were not doing an extern "C".
I see that you used the old #ifdef __cplusplus approach. Should we use
the _BEGIN_STD_C/_END_STD_C macros that are used elsewhere, such as
$TARGET/include/stdlib.h? See the $TARGET/include/_ansi.h file, at the
bottom:
/* ISO C++. */
#ifdef __cplusplus
#if !(defined(_BEGIN_STD_C) && defined(_END_STD_C))
#ifdef _HAVE_STD_CXX
#define _BEGIN_STD_C namespace std { extern "C" {
#define _END_STD_C } }
#else
#define _BEGIN_STD_C extern "C" {
#endif
#endif
#else
#define _END_STD_C
#endif
This way, namespace std is handled correctly too.
Take care,
-Bob
