GCC 4.1.1 m68k-rtems generating invalid code for -m5307 proce ssor ?
Kirspel, Kevin
kevin.kirspel at optimedical.com
Tue Jun 26 12:42:58 UTC 2007
True.
-----Original Message-----
From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
Sent: Tuesday, June 26, 2007 8:41 AM
To: Kirspel, Kevin
Cc: 'Chris Johns'; Ian Caddy; 'rtems-users at rtems.org'
Subject: RE: GCC 4.1.1 m68k-rtems generating invalid code for -m5307 proce
ssor ?
On Tue, 2007-06-26 at 08:26 -0400, Kirspel, Kevin wrote:
> The issue is that when I compile the rtems toolchains for m68k, they do
not
> generate the libraries for the m5307 processor. I am currently trying to
see
> how I can get these libraries generated.
Why do you need such library? Wanting to have one for each and every
variant of a cpu would be pretty silly and inapplicable.
You'd normally want to chose a "cpu variant" from a set of cpu-variants
a toolchain supports that "works reasonably" for you, not the one that
"squeezes out the max" from a cpu.
Ralf
