FW: C compiler cannot create executables
Amalaye Oyake amalaye.oyake at jpl.nasa.gov
Fri Mar 30 19:33:22 UTC 2007
Ok, I have checked out that branch. The instructions say use the ./bootstrap
script, but that script seems to bomb miserably.
/RTEMS_latest/rtems$ ./bootstrap
cp: cannot create regular file `[$1]/install-sh': No such file or directory
automake: configure.ac: installing `[$1]/install-sh'
    error while copying
blah blah blah
-----Original Message-----
From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
Sent: Thursday, March 29, 2007 2:03 PM
To: Amalaye Oyake
Cc: rtems-users at rtems.org
Subject: Re: C compiler cannot create executables
On Thu, 2007-03-29 at 10:40 -0700, Amalaye Oyake wrote:
> I was rebuilding RTEMS and I was running into this problem:
> checking for C compiler default output file name... configure: error: C
> compiler cannot create executables.
> I am assuming that configure was using the cross compiler tools that I
built
> ... it seemed to build everything else just fine, but kept getting hung
here
> ~ pc386/configure failed for pc386.
I presume this to be a known issue with the 4.7.0 release and building
i386 targets on non-multilib'ed x86_64 systems.
Can you try with RTEMS CVS from rtems-4-7-branch?
Ralf
