C compiler cannot create executables
Amalaye Oyake
amalaye.oyake at jpl.nasa.gov
Fri Mar 30 20:48:15 UTC 2007
Fixed:
While my autoconf was up to date, my automake was not. Debian/Ubuntu users
take note (since I am using the latest Ubuntu ~ Edgy) ... I manually brought
automake to v 10 (Edgy still seems to use an old automake) and everything
seems happy - bootstrap is chugging as I speak.
-----Original Message-----
From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
[mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
Of Amalaye Oyake
Sent: Friday, March 30, 2007 12:33 PM
To: 'Ralf Corsepius'
Cc: rtems-users at rtems.org
Subject: FW: C compiler cannot create executables
Ok, I have checked out that branch. The instructions say use the ./bootstrap
script, but that script seems to bomb miserably.
/RTEMS_latest/rtems$ ./bootstrap
cp: cannot create regular file `[$1]/install-sh': No such file or directory
automake: configure.ac: installing `[$1]/install-sh'
error while copying
blah blah blah
From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
Sent: Thursday, March 29, 2007 2:03 PM
To: Amalaye Oyake
Subject: Re: C compiler cannot create executables
On Thu, 2007-03-29 at 10:40 -0700, Amalaye Oyake wrote:
> I was rebuilding RTEMS and I was running into this problem:
> checking for C compiler default output file name... configure: error: C
> compiler cannot create executables.
> I am assuming that configure was using the cross compiler tools that I
built
> ... it seemed to build everything else just fine, but kept getting hung
here
> ~ pc386/configure failed for pc386.
I presume this to be a known issue with the 4.7.0 release and building
i386 targets on non-multilib'ed x86_64 systems.
Can you try with RTEMS CVS from rtems-4-7-branch?
Ralf
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
