Timer_Initialize
WuHao derossi at mail.ustc.edu.cn
Sat May 5 07:22:17 UTC 2007
Hi:
  I use RTEMS4 and the pc386 BSP and got some problem with Timer_Initialize.
   1. I search for the old mail_lists and find a similar problem:
  Timer_Initialize
    * /Date/: Fri, 08 Oct 1999 10:28:18 +0200
    * /From/: reuther at kinzinger.de (Udo Reuther)
    * /Subject/: Timer_Initialize
Hello all,
I use RTEMS4 and the pc386 BSP.
I tried to do some timing measurements and copied code from one of the
timing tests.
But the call to Timer_Initialize failed, reporting "raw handler
connexion failed".
This is what happened:
/* Function Timer_Initialize in file timer.c:238 */
if (!i386_set_idt_entry (&timer_raw_irq_data)) {
  printk("raw handler connexion failed\n");
  rtems_fatal_error_occurred(1);
/* Function i386_set_idt_entry im file cpu.c:83 */
if (get_hdl_from_vector(irq->idtIndex) != default_raw_irq_entry.hdl) {
  return 0;
The returned value is (void (*)()) 0x18dd50 <rtems_irq_prologue_0>,
whereas default_raw_irq_entry.hdl = (void (*)()) 0x18de4d
<default_raw_idt_handler>.
What did I miss ?
Regards,
	Udo
What is the resolution?
2.Also in Timer_initialize
/*code in Timer_initialize in file timer.c*/
while (Ttimer_val == 0)
continue;
When an ISR calls Timer_initialize,the system will loop forever since in
ISR interrupts are disabled.
(I found this when I try to run tm27 test.The task1 installs a
Isr_handler,then the Isr_handler will call Timer_initialize.)
thanks.
