Howto cancel a blocked termios read request
Wolfram Wadepohl Wolfram.Wadepohl at ek-automation.com
Tue May 8 06:35:35 UTC 2007
i need to cancel a blocked termios read request.
the request blocks at the tty->rawInBuf.Semaphore in fillBufferQueue():
	 * Wait for characters
	if ( wait ) {
		sc = rtems_semaphore_obtain (tty->rawInBuf.Semaphore,
			tty->rawInBufSemaphoreOptions,
			timeout);
		if (sc != RTEMS_SUCCESSFUL)
			break;
using ioctl to set c_cc[VMIN] = c_cc[VTIME] = 0 does not help, because it
changes only tty->rawInBufSemaphoreOptions, which will be in effect for the
*next* call to rtems_semaphore_obtain().
should we put an extra rtems_semaphore_release() call in the code, when we
set tty->rawInBufSemaphoreOptions to RTEMS_NO_WAIT (line 571) in case of
c_cc[VMIN] = c_cc[VTIME] = 0?
any other suggestions to cancel a blocked read?
thanks.
Schöne Grüße aus Reutlingen
Wolfram Wadepohl
Forschung & Entwicklung
E&K AUTOMATION
Indumat GmbH & Co. KG
Siemensstraße 3
72766 Reutlingen
Deutschland
Tel.  +49 7121 514-289
Fax   +49 7121 514-299
eMail Wolfram.Wadepohl at ek-automation.com
       W.Wadepohl at ieee.org
WWW   http://www.ek-automation.com
       http://www.indumat.de
Diese Nachricht ist keine geschäftliche Mitteilung i. S. des EHUG.
Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft) Anhänge.
Senden Sie mir einfachen Text, HTML oder PDF.
Siehe http://www.gnu.org/philosophy/no-word-attachments.de.html
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20070508/2c1ead8c/attachment.bin>
