instruction access exception
Ingolf Steinbach
Ingolf.Steinbach at jena-optronik.de
Wed May 9 10:08:07 UTC 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi,
hwulf at et-inf.fho-emden.de schrieb:
> Now, when I start the program with #define DEBUG, the program stops at
> an irregular instruction and the following lines are printed to the
> console:
> Unexpected trap <0x01> at address 0xd0142300c
Just a wild guess: Could this be caused by the bug discussed
recently which leads to stack overflows when interrupts
occur too frequently?
If the program uses printf() (or any other output to stdout)
extensively, the UART will probably generate a high interrupt
load and might trigger a stack overflow.
Cheers
Ingolf
Ingolf Steinbach
Software Engineer
Jena-Optronik GmbH
Prüssingstraße 41
07745 Jena
Tel: +49 3641 200-216
Fax: +49 3641 200-220
E-Mail: ingolf.steinbach at jena-optronik.de
http://www.jena-optronik.de
President & CEO: Dietmar Ratzsch I CFO: Dr. Harald Bruhn
Sitz der Gesellschaft: Jena l Handelsregister: AG Jena HRB 201.869
Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte
Informationen. Wenn Sie nicht der richtige Adressat sind, oder diese
E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
This message is intended to be confidential and may be privileged. If
you are not the intended recipient, please delete this e-mail from your
system immediately and notify us of the erroneous transmission to you.
Any disclosure, use, copying, or distribution of this E-mail is
prohibited.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD4DBQFGQZ2HPugQggQN1ScRAtW5AJYo8RqL29RHzYy0cdQMmB6sWKWgAJ9WBSNK
XNVibNF8AXL3jJnRixIZiA==
=aBe3
-----END PGP SIGNATURE-----
