instruction access exception
Joel Sherrill
joel.sherrill at oarcorp.com
Wed May 9 11:21:22 UTC 2007
Ingolf Steinbach wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> hwulf at et-inf.fho-emden.de schrieb:
>> Now, when I start the program with #define DEBUG, the program stops at
>> an irregular instruction and the following lines are printed to the
>> console:
>> Unexpected trap <0x01> at address 0xd0142300c
The SPARC BSPs all end with a trap. Double check that this isn't a normal
exit on an error detection path. The key is whether or not that is a
valid address
for code in your program.
> Just a wild guess: Could this be caused by the bug discussed
> recently which leads to stack overflows when interrupts
> occur too frequently?
> If the program uses printf() (or any other output to stdout)
> extensively, the UART will probably generate a high interrupt
> load and might trigger a stack overflow.
This disclaimer is at odds with sending a message to a public list.
It was never intended to be private or confidential and was also
immediately archived.
> Cheers
> Ingolf
> Ingolf Steinbach
> Software Engineer
> Jena-Optronik GmbH
> Prüssingstraße 41
> 07745 Jena
> Tel: +49 3641 200-216
> Fax: +49 3641 200-220
> E-Mail: ingolf.steinbach at jena-optronik.de
> http://www.jena-optronik.de
> President & CEO: Dietmar Ratzsch I CFO: Dr. Harald Bruhn
> Sitz der Gesellschaft: Jena l Handelsregister: AG Jena HRB 201.869
> Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte
> Informationen. Wenn Sie nicht der richtige Adressat sind, oder diese
> E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> This message is intended to be confidential and may be privileged. If
> you are not the intended recipient, please delete this e-mail from your
> system immediately and notify us of the erroneous transmission to you.
> Any disclosure, use, copying, or distribution of this E-mail is
> prohibited.
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD4DBQFGQZ2HPugQggQN1ScRAtW5AJYo8RqL29RHzYy0cdQMmB6sWKWgAJ9WBSNK
> XNVibNF8AXL3jJnRixIZiA==
> =aBe3
> -----END PGP SIGNATURE-----
> rtems-users mailing list
> rtems-users at rtems.com
