Creation of initial task fails with RTEMS_UNSATISFIED
Ingolf Steinbach
ingolf.steinbach at googlemail.com
Thu May 10 07:45:48 UTC 2007
Joel Sherrill wrote on 2006-08-24:
> I suspect that for whatever reason, the configure ran out of
> memory for stack space before it ran out of task control blocks.
> If you can post a small and complete example, I can probably tell
> you precisely what happened.
Please have a look at the example code below. The reason for
the problem might be that _Thread_Initialize() is called *four*
times: once for
- the idle task
- the INIT task
- the USR1 task
- the USR2 task.
On RTEMS 4.6.5, the assertion fails because the second
rtems_task_create() (for USR2) fails with RTEMS_UNSATISFIED.
Do I really have to count the idle task, too, when configuring
CONFIGURE_MAXIMUM_TASKS?
Cheers
Ingolf
--------8<--------8<--------8<--------
#include <assert.h>
rtems_task Init(rtems_task_argument unused);
#define CONFIGURE_INIT
#define CONFIGURE_MICROSECONDS_PER_TICK 500 /* 0.5 millisecond */
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 3
#define CONFIGURE_MAXIMUM_PERIODS 1
#define CONFIGURE_MAXIMUM_SEMAPHORES 2
#define CONFIGURE_MAXIMUM_TIMERS 1
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 1
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT_TASK_PRIORITY 128
#define CONFIGURE_INIT_TASK_NAME rtems_build_name('I','N','I','T')
#define CONFIGURE_INIT_TASK_STACK_SIZE (2*RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_INIT_TASK_ATTRIBUTES (RTEMS_DEFAULT_ATTRIBUTES |
RTEMS_FLOATING_POINT)
#define CONFIGURE_EXTRA_TASK_STACKS (2*RTEMS_MINIMUM_STACK_SIZE)
#include <confdefs.h>
rtems_task Init(rtems_task_argument unused) {
rtems_id taskId;
rtems_status_code status = rtems_task_create(
rtems_build_name('U','S','R','1'),
130,
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_DEFAULT_MODES,
RTEMS_DEFAULT_ATTRIBUTES,
&taskId);
rtems_build_name('U','S','R','2'),
129,
2*RTEMS_MINIMUM_STACK_SIZE,
RTEMS_PREEMPT | RTEMS_TIMESLICE |RTEMS_NO_ASR |
RTEMS_INTERRUPT_LEVEL(0),
RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT,
&taskId);
assert(status == RTEMS_SUCCESSFUL);
