error inet.h library
Vivian Paola Guerrero Rodriguez vivianpaolag at hotmail.com
Thu May 10 15:05:45 UTC 2007
Hi Till,
I have including the libraries that you named in your e-mail and also I'm using extern "C" as you showed me.
I'm programming in C++, so I don't know if the version of rtems 4.7 changed the way to use libraries for C++ or something like that.
Do you know about this?
Thanks for your help !!
> Date: Wed, 9 May 2007 16:07:03 -0700
> From: strauman at slac.stanford.edu
> To: vivianpaolag at hotmail.com
> CC: rtems-users at rtems.org
> Subject: Re: error inet.h library
> Vivian Paola Guerrero Rodriguez wrote:
> > Hi,
> > I'm migrating from rtems 4.6 to 4.7.1. When I compile my program I get two errors about the inet.h library:
> > program.cc:222 error: inetntoa  was not declared in this scope
> > program.cc:111 error: inet_aton was not declared in this scope
> Please provide more info. I just tried to compile a very simple stub:
> #include
> #include
> #include
> #include
> extern "C" char* inet_ntoa_wrap(struct in_addr x)
>         return inet_ntoa(x);
> but this compiles fine under 4.6.5 and 4.7 for me
> T.
> > I'm including the library that contents these funtions :  #include
> >        #include
> > So I don't understand what is the reason for these errors, could be possible the directory of this library had been changed for the new version fo rtems ?
> > Thanks a lot for your help !
> > _________________________________________________________________
> > See what you’re getting into…before you go there.
> > http://newlivehotmail.com/?ocid=TXT_TAGWL_migration_HM_viral_preview_0507
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
