Howto cancel a blocked termios read request
Joel Sherrill
joel.sherrill at oarcorp.com
Tue May 8 11:19:34 UTC 2007
Wolfram Wadepohl wrote:
> i need to cancel a blocked termios read request.
> the request blocks at the tty->rawInBuf.Semaphore in fillBufferQueue():
> * Wait for characters
> if ( wait ) {
> sc = rtems_semaphore_obtain (tty->rawInBuf.Semaphore,
> tty->rawInBufSemaphoreOptions,
> timeout);
> if (sc != RTEMS_SUCCESSFUL)
> break;
> using ioctl to set c_cc[VMIN] = c_cc[VTIME] = 0 does not help, because
> it changes only tty->rawInBufSemaphoreOptions, which will be in effect
> for the *next* call to rtems_semaphore_obtain().
> should we put an extra rtems_semaphore_release() call in the code,
> when we set tty->rawInBufSemaphoreOptions to RTEMS_NO_WAIT (line 571)
> in case of c_cc[VMIN] = c_cc[VTIME] = 0?
> any other suggestions to cancel a blocked read?
Can that semaphore be flushed? I don't know what the API would be to
the user but that should
end up returning not satisfied.
It would also allow it to be canceled on a signal.
--joel
> thanks.
> rtems-users mailing list
> rtems-users at rtems.com
