Undefined macro ALIGN when using CMSG_NXTHDR macro
Paul Whitfield
paulw at omnitronics.com.au
Thu May 17 00:20:41 UTC 2007
Joel Sherrill wrote:
> Paul Whitfield wrote:
>> Hi All,
>> I have some code I am looking at possibly porting to rtems
>> (avahi).
> This is LGPL so be aware of the implications of linking this with
> your application.
Now you have me worried... I thought as long as I did not
alter the library using the code in a embedded application
was OK. I thought that this was reason for the "Lesser".
>> However, the code uses recvmsg and the CMSG_NXTHDR macro.
>> This results in a compile error because the ALIGN macro
>> is not defined.
> I am guessing that you could define it to nothing and try that.
> Any guess what they are trying to align and why?
I was hoping that someone on the list who know the
answer to that question.
Some internet research later shows this is a
mechanism for getting at "ancillary" data
the socket message. Primarily this looks
to by a IPv6 function.
The issue with the code using poll is a show
stopper for me anyway. It would require too
much work (and modifying the library), so
I will not be doing any more work on this.
I will go back to plan A which is to use the apple
mDNS / Bonjour code.
Thanks for the help.
Regards
Paul
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
