Multiple telnet sessions
Thu May 17 16:02:21 UTC 2007
Brett Swimley wrote:
> Hi,
> I'm working on a telnet like server for a Python interpreter (which I'm
> hoping to post on the wiki) and am running into some problems.
> I thought I would go back to the basics and work with the telnetd server
> provided.
> I have initialized as follows:
> #ifdef ENABLE_TELNET
>    * Just in case we may want to telnet to the application.
>   rtems_pty_maximum_ptys = 10;
>   rtems_io_register_driver( 0, &pty_driver_address_table, &pty_major );
>   rtems_telnetd_main(0, NULL);
> #endif
> Things work OK until I get multiple telnet sessions running.  Then,
> typing text into the first session causes an exception in
> _Thread_Dispatch() in _CPU_Context_restore_fp() (which may be an
> artifact of another issue).
Sounds like the stack checker kicking in and trying to using printf
when it is questionable to do so. If you are on a recent enough
RTEMS, stack checker uses printk.
If you have printk support in your BSP, I would recommend
changing the printf's in check.s to printk and trying again.
> Has anyone run multiple telnet sessions concurrently?  Am I setting up
> the pty driver correctly?
> Thanks in advance,
> Brett Swimley
> rtems-users mailing list
> rtems-users at rtems.com
