Multiple telnet sessions
Brett Swimley brett.swimley at aedbozeman.com
Thu May 17 18:39:34 UTC 2007
I found my problem.
It turns out the the FP context switch WAS incorrect.
I had added support for the MCF547x FPU, and had an incorrect size for
the space required to store the floating point registers.
Brett
Joel Sherrill wrote:
> Brett Swimley wrote:
>> Hi,
>> I'm working on a telnet like server for a Python interpreter (which
>> I'm hoping to post on the wiki) and am running into some problems.
>> I thought I would go back to the basics and work with the telnetd
>> server provided.
>> I have initialized as follows:
>> #ifdef ENABLE_TELNET
>>    * Just in case we may want to telnet to the application.
>>   rtems_pty_maximum_ptys = 10;
>>   rtems_io_register_driver( 0, &pty_driver_address_table, &pty_major );
>>   rtems_telnetd_main(0, NULL);
>> #endif
>> Things work OK until I get multiple telnet sessions running.  Then,
>> typing text into the first session causes an exception in
>> _Thread_Dispatch() in _CPU_Context_restore_fp() (which may be an
>> artifact of another issue).
> Sounds like the stack checker kicking in and trying to using printf
> when it is questionable to do so. If you are on a recent enough
> RTEMS, stack checker uses printk.
> If you have printk support in your BSP, I would recommend
> changing the printf's in check.s to printk and trying again.
>> Has anyone run multiple telnet sessions concurrently?  Am I setting
>> up the pty driver correctly?
>> Thanks in advance,
>> Brett Swimley
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
