Multiple telnet sessions
Joel Sherrill
joel.sherrill at oarcorp.com
Thu May 17 18:54:33 UTC 2007
Brett Swimley wrote:
> I found my problem.
> It turns out the the FP context switch WAS incorrect.
> I had added support for the MCF547x FPU, and had an incorrect size for
> the space required to store the floating point registers.
That sounds like a deadly problem since it probably blew away some other
thread's information. :(
When you are happy with that MCF547x FPU support, you can submit it by
itself. I expect that
no matter what version of RTEMS you are using, I can merge it easily on
the head.
--joel
> Brett
>>> Hi,
>>> I'm working on a telnet like server for a Python interpreter (which
>>> I'm hoping to post on the wiki) and am running into some problems.
>>> I thought I would go back to the basics and work with the telnetd
>>> server provided.
>>> I have initialized as follows:
>>> #ifdef ENABLE_TELNET
>>> * Just in case we may want to telnet to the application.
>>> rtems_pty_maximum_ptys = 10;
>>> rtems_io_register_driver( 0, &pty_driver_address_table, &pty_major );
>>> rtems_telnetd_main(0, NULL);
>>> #endif
>>> Things work OK until I get multiple telnet sessions running. Then,
>>> typing text into the first session causes an exception in
>>> _Thread_Dispatch() in _CPU_Context_restore_fp() (which may be an
>>> artifact of another issue).
>> Sounds like the stack checker kicking in and trying to using printf
>> when it is questionable to do so. If you are on a recent enough
>> RTEMS, stack checker uses printk.
>> If you have printk support in your BSP, I would recommend
>> changing the printf's in check.s to printk and trying again.
>>> Has anyone run multiple telnet sessions concurrently? Am I setting
>>> up the pty driver correctly?
>>> Thanks in advance,
>>> Brett Swimley
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
