Problems with RTEMS-4.7.1 pc386 BSP
Eric Norum
norume at aps.anl.gov
Wed May 23 15:12:25 UTC 2007
On May 23, 2007, at 10:04 AM, Joel Sherrill wrote:
> Eric Norum wrote:
>> I'm surprised to find problems with the pc386 BSP. Surely this
>> must be one of the more heavily used architectures. so why am I
>> the first to run into this problem?
> I checked the build logs for the 4.7 branch and the pc386 BSP for
> changes
> since 4.7.1 -- no build errors and no changes. The last build did
> include
> all tests and was on 21 May.
> Can you generate a .map and see what happened?
This is probably a link order issue. If the BSP library is loaded
before the librtemscpu.a library there's no problem -- or if no
references to __assert have been made at the point where the
librtemscpu.a library is linked theres no problem. My application is
being linked with a command from the EPICS build system which might
be the reason that different code is being pulled from the libraries
or that the libraries are linking in a different order.
> It does beg the question -- why does the pc386 BSP have its own
> assert?
I think that this is so the BSP can put up the message on the console
and wait for a key to be pressed. Otherwise the message flashes onto
the screen and disappears immediately.
For now I've just removed the assert in the BSP.
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
