RTEMS autotools installation on mingw
Sven.BIEBAUT at be.thalesgroup.com
Mon Nov 5 12:39:28 UTC 2007
Hello,
as a new user to rtems, i tried to install the mingw based windows tools (i
want to combine it with other windows based
development tools).
I installed mingw, msys and msysDTK and proceeded as per the wiki page with
the RTEMS tools installer(rtems4.8-tools-16.exe). As this development pc is
not internet connected, I downloaded the packages first on a memory stick
and installed them from there.
The RTEMS installer however complains about "Cannot open
not-found/etc/fstab. MSYS mount point not added". Apparently this seems only
to affect the autotools sub package. I tried setting the HOME environment
variable, but this does not change alot.
If I continue and disregard the message it will proceed with the actual
compiler installation, but in the end complain that it couldn't find mingw.
Is there something that I missed ? Do I need administrator rights or are
there other environment variables necessary?
Thanks in advance,
Sven Biebaut
