No acceptable C compiler found
Jalpan Dholakia
jalpan.dholakia at nxp.com
Mon Nov 12 16:25:20 UTC 2007
Hello,
I am configuring RTEMS4.7.1 for Arm target through MINGW. I have
downloaded appropriate compilers from RTEMS ftp. I have also tested
arm-rtems4.7-gcc.exe and it is generating .o and .S file. I have also
exported proper PATH.
I am giving address of the directory which contains arm tools through - -
prefix. Though I could not able to configure. I am getting error that
error: No acceptable C compiler found in $PATH
Could you please point me the problem?
Thank you.
Regards.
URL: <http://lists.rtems.org/pipermail/users/attachments/20071112/e1bd20a6/attachment.html>
