No acceptable C compiler found
Mon Nov 12 23:25:12 UTC 2007
Jalpan Dholakia wrote:
> Hello,
> I am configuring RTEMS4.7.1 for Arm target through MINGW. I have
> downloaded appropriate compilers from RTEMS ftp. I have also tested
> arm-rtems4.7-gcc.exe and it is generating .o and .S file. I have also
> exported proper PATH.
Did you test this in a cmd.exe box or the MSYS shell ?
> I am giving address of the directory which contains arm tools through -
> - prefix. Though I could not able to configure. I am getting error that
> error: No acceptable C compiler found in $PATH
> Could you please point me the problem?
It will be the PATH variable. Configure needs a valid path set.
Could you please send me the config.log and the PATH variable.
Regards
