Has anybody built RTEMS TIc4x successfully?
wenye zhang
zhangwenye2008 at yahoo.com.cn
Wed Nov 14 12:23:38 UTC 2007
Hello all
I want to know has anybody built RTEMS Tic4x successfully. If you have, can you tell me the version of tools and rtems?Thanks you very much.
I tried the tools as follow:
autoconf-2.60.tar.bz2
automake-1.10.tar.bz2
binutils-2.17.90.tar.bz2
gcc-core-3.4.6.tar.bz2
newlib-1.15.0.tar.gz
binutils-2.17.90-rtems4.8-20070807.diff
newlib-1.15.0-rtems4.8-20070413.diff.
The rtems version is rtems-4.6.6.tar.bz2.
I configured―made―installed the toolchain successfully. Then I build rtems as follow.
cd build-rtems
../rtems-4.6.6/configure --target=tic4x-rtems4.8 --enable-rtemsbsp=c4xsim --disable-posix --disable-itron --disable-networking --disable-cxx --disable-test --disable-multiprocessing --prefix=/usr/opt
make all
But there was an error :
Making all in optman
gmake[3]: Entering directory `/home/temptools/build-rtems/tic4x-rtems4.8/c/c4xsi
m/optman'
mkdir o-optimize
tic4x-rtems4.8-gcc --pipe -B../../.././lib/ -B../../.././c4xsim/lib/ -specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-optman\" -DPACKAGE_TARNAME=\"rtems-c-src-optman\" -DPACKAGE_VERSION=\"4.6.6\" -DPACKAGE_STRING=\"rtems-c-src-optman\4.6.6\" -DPACKAGE_BUGREPORT=\"rtems-bugs at rtems.com\" -isystem ../../.././c4xsim/lib/include -mcpu=40 -D__rtems__ -O1 -g -Wall -ansi -fasm -o o-optimize/no-dpmem.o -c ../../../../../rtems-4.6.6/c/src/optman/rtems/no-dpmem.c
tic4x-rtems4.8-gcc --pipe -B../../.././lib/ -B../../.././c4xsim/lib/ -specs bsp_specs -qrtems -mcpu=40 -D__rtems__ -O1 -g -Wall -ansi -fasm -o o-optimize/no-dpmem.rel -qnolinkcmds -nostdlib -Wl,-r o-optimize/no-dpmem.o
collect2: ld terminated with signal 11 [Segmentation fault], core dumped
gmake[3]: *** [o-optimize/no-dpmem.rel] Error 1
gmake[3]: Leaving directory `/home/temptools/build-rtems/tic4x-rtems4.8/c/c4xsim/optman'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/home/temptools/build-rtems/tic4x-rtems4.8/c/c4xsim'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/temptools/build-rtems/tic4x-rtems4.8/c'
make: *** [all-recursive] Error 1
I feel there are errors for the toolchain to ld .rel files. Has anybody met the same question?
@yahoo.cn 新域名、无限量,快来抢注!
URL: <http://lists.rtems.org/pipermail/users/attachments/20071114/0c56b3de/attachment.html>
