External RAM filesystem
Aitor.Viana.Sanchez at esa.int
Tue Nov 20 16:00:58 UTC 2007
Hi,
Yes, I am also quite interested in that solution but i am still one step
back stuck with the IMFS trying to mount an external RAMDisk and using it
properly. And, i don't know whether the problems I am getting are because
of my configuration and or they are coming from the RTEMS IMFS.
Basically, the configuration I got is this:
rtems_bdbuf_config rtems_bdbuf_configuration[] = {
{ 512, 200, (unsigned char *) _SDRAM_FS_ADDR }
int rtems_bdbuf_configuration_size =(
sizeof(rtems_bdbuf_configuration)
/sizeof(rtems_bdbuf_configuration[0]));
rtems_ramdisk_config rtems_ramdisk_configuration[] = {
{512, 200, (void *) _SDRAM_FS_ADDR}
size_t rtems_ramdisk_configuration_size = (
sizeof(rtems_ramdisk_configuration)
/sizeof(rtems_ramdisk_configuration[0]));
and when I mount the ramdisk space
memset(&rqdata, 0, sizeof(rqdata));
rqdata.OEMName = "Rtems";
rqdata.VolLabel = "RAMDISK";
rqdata.fattype = MSDOS_FMT_FATANY;
rqdata.quick_format = TRUE;
assert(msdos_format("/dev/ramdisk0", &rqdata) == 0);
status = (rtems_status_code)rtems_fsmount(
fs_mnt_table,
sizeof(fs_mnt_table)/sizeof(fs_mnt_table[0]),
NULL
everything goes well. Now if I try to store files sized ~50Kbyte,
gorgeous...but now, writting files sized ~2MB raised an I/O error in the
fwrite routine and I do not understand why.
any clue?
//avs
rtems-users-bounces at rtems.org wrote on 11/20/2007 03:22:18 PM:
> Hi Joel,
> I should probably join in the conversation too, as a persistent RAM
> disk will be important in our upcoming RTEMS applications.
> I like this idea for the IMFS.
> But a question: for our vxWorks based systems, we create a RAM disk
> in an area of RAM that is preserved during OS restarts. We can then
> verify/remount the disk after vxWorks restarts. Would this be a
> possibility for the IMFS with a custom pool/malloc/free ?
> Thanks,
> Alan
> On Nov 20, 2007, at 9:05 AM, Joel Sherrill wrote:
> > I'm late in the discussion but I proposed a couple of years
> > ago adding a configuration item for the IMFS. If you defined
> > a structure with three callback functions, you could change
> > where memory was allocated in the IMFS.
> > + initialize pool (default NULL)
> > + allocate memory (default malloc)
> > + free memory (default free)
> > Change the IMFS code to use the provided functions and
> > it can easily be switched.
> > --joel
> rtems-users mailing list
> rtems-users at rtems.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20071120/5e0ff9cd/attachment.html>
