Avoiding power-down on leon2
John Pickwick
john.pickwick at free.fr
Fri Nov 9 20:53:06 UTC 2007
Hi,
I have the same concern with LEON2 and I've done it with a low-priority task
that uses an infinite busy loop.
I have checked that the IDLE task is never called (through the tick counter
of the CPU tool).
For this reason, recently I asked here if it was possible to remove or
substitute the IDLE task thread (mainly to avoid anxious questions from
customers on this topic since I'm convinced by the solution above). You can
do it (changing the #define that goes in the CPU table) but then you need to
recompile the BSP.
Joel suggested to make the changes to include the CPU table in the regular
table. I did not have time yet to look at it.
regards,
John
----- Original Message -----
From: "Ingolf Steinbach" <ingolf.steinbach at googlemail.com>
To: <rtems-users at rtems.org>
Sent: Thursday, November 08, 2007 4:53 PM
Subject: Avoiding power-down on leon2
> Hi,
> which measures do you recommend for avoiding processor power-down on
> leon2 when using RTEMS 4.6.5? Are there any configuration options?
> Should we write our own "idle" task (implementing a busy loop)? Would
> implementing a busy loop in a low-priority task really guarantee that
> the processor is not powered down by the operating system?
> Kind regards
> Ingolf
> rtems-users mailing list
> rtems-users at rtems.com
