External RAM filesystem
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Tue Nov 13 16:47:44 UTC 2007
Hi,
yes, it should be possible. There still exists a ram disk driver, which
performs this function, see:
cpukit/libblock/src/ramdisk.c
We used it for our very first tests of the FATFS. If I recall correctly,
these are the steps to work with it:
- define a rtems_ramdisk_config data structure (e.g. in the init module)
with the fixed name "rtems_ramdisk_configuration".
- you can/must define the block size, the number of blocks and location
in this structure
- If you add the RAMDISK_DRIVER_TABLE_ENTRY to your device driver table,
it will initialize automatically when your system comes up
- Or, you can initialize the ramdisk with "ramdisk_initialize".
- Next, you must format the ramdisk (use msdos_format function in
cpukit/libfs/src/dosfs/msdos_format.c).
- Then you can mount the ramdisk as a (unpartitioned) volume with
msdos_initialze().
I hope I am rather acurate on these steps.
It would be nice if you could give us feedback, when things work.
And it would be even nicer, if you could write a wiki entry on this
under www.rtems.com/wiki
wkr,
Thomas.
Aitor.Viana.Sanchez at esa.int schrieb:
> Hi all,
> is it possible to configure RTEMS somehow to access and external RAM
> memory address where a FAT32 (for instance) file system is placed? Is it
> possible to configure the address and size?
> Thanks in advance.
> Aitor
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
