External RAM filesystem
Aitor.Viana.Sanchez at esa.int
Wed Nov 14 09:10:49 UTC 2007
Hi,
thanks a lot for the information...i will try to set it up. I will let you
know once the things are working.
Cheers,
Aitor
Thomas Doerfler <Thomas.Doerfler at embedded-brains.de> wrote on 11/13/2007
05:47:44 PM:
> Hi,
> yes, it should be possible. There still exists a ram disk driver, which
> performs this function, see:
> cpukit/libblock/src/ramdisk.c
> We used it for our very first tests of the FATFS. If I recall correctly,
> these are the steps to work with it:
> - define a rtems_ramdisk_config data structure (e.g. in the init module)
> with the fixed name "rtems_ramdisk_configuration".
> - you can/must define the block size, the number of blocks and location
> in this structure
> - If you add the RAMDISK_DRIVER_TABLE_ENTRY to your device driver table,
> it will initialize automatically when your system comes up
> - Or, you can initialize the ramdisk with "ramdisk_initialize".
> - Next, you must format the ramdisk (use msdos_format function in
> cpukit/libfs/src/dosfs/msdos_format.c).
> - Then you can mount the ramdisk as a (unpartitioned) volume with
> msdos_initialze().
> I hope I am rather acurate on these steps.
> It would be nice if you could give us feedback, when things work.
> And it would be even nicer, if you could write a wiki entry on this
> under www.rtems.com/wiki
> wkr,
> Thomas.
> Aitor.Viana.Sanchez at esa.int schrieb:
> > Hi all,
> > is it possible to configure RTEMS somehow to access and external RAM
> > memory address where a FAT32 (for instance) file system is placed? Is
it
> > possible to configure the address and size?
> > Thanks in advance.
> > Aitor
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> embedded brains GmbH
> Thomas Doerfler Obere Lagerstr. 30
> D-82178 Puchheim Germany
> Tel. : +49-89-18 90 80 79-2
> Fax : +49-89-18 90 80 79-9
> email: Thomas.Doerfler at embedded-brains.de
> PGP public key available on request
URL: <http://lists.rtems.org/pipermail/users/attachments/20071114/be4fb2d7/attachment-0001.html>
