No acceptable C compiler found
Tue Nov 13 20:45:39 UTC 2007
Ralf Corsepius wrote:
> On Tue, 2007-11-13 at 07:59 -0600, Joel Sherrill wrote:
>> + MinGW doesn't run on Vista correctly.  The native compiler
>>     dies compiling hello world with a message like
>>      "cc1 not found".
> cc1 not found indicates a toolchain relocation error.
> In general, GCCs based toolchains are not relocatible and must be
> installed into the prefix they have been configured for.
Right but this is only happening on Vista.  I don't know
what subtle problem is happening but we installed on
a mix of 5 XP and Vista computers following the same
instructions.  XP's were OK.  Vista's all gave the same error.
Looks like the MinGW tools depend on something that
can't happen on Vista.
>>  We searched online and others have
>>      run into this but the only solution I saw was to put the
>>      directory with cc1 in your PATH but that results in the
>>      RTEMS cross compiler finding the native cc1 not the
>>      cross one.
> Right. As you might recall, cross tools are named <host>-<tool>.
> You MUST not put the directory containing cc1 into $PATH.
Yep.  Once I realized that was the only solution we had
found, we gave up on Vista.  That is a totally unacceptable
solution.
-joel
> Ralf
