No acceptable C compiler found
Ralf Corsepius ralf.corsepius at rtems.org
Tue Nov 13 16:10:15 UTC 2007
On Tue, 2007-11-13 at 23:49 +0800, Ray wrote:
> Hi, Jalpan Dholakia
> Can you post another config.log? the config.log should located in some subdirectory.
> when you type:  configure --target=arm-rtems.......
> you will get information like:
> $> entering /home/yourhome/rtems4.7/dir1/dir2/
> $> error:No acceptable C compiler found
> Then, the error configure log should be in /home/yourhome/rtems4.7/dir1/dir2/
> BTW, how about if you try configure --target=arm-rtems4.7 instead of configure --target=arm-rtems?
Good point! The value being passed to --target=... must match the
target-prefix of the toolchain.
Ralf
